pliant par Allen Elishevitz
Messagepar Moonlight » 12 Mar 2008 02:10
What I am going to try to attempt to pull off is a Scarab with a slightly modified blade, a compound grind with some other goodies on the blade. The handle is going to be all titanium with lots of machining. It will also feature a very special E-Lock and before I forget: it is going to be a full auto. But I don't want to spoil the excitement so I am not going to say what else I have planned for the knife...
So there will be no goofing off for the next few days
Like for the fixed blade Build-Off this is going to have a lot of photos, probably even more.
The materials, time stamps and some technical drawings
Layout fluid on the materials
Scribing the patterns on the different materials
Ready for cutting
Cutting all the parts on the bandsaw
All the parts are cut out
Blade and handles profiled
Handle materials in the lapping machine
The lapping machine in action!
The parts after the lapping.…. Ooooooh nice and flat
Spotting all the holes on my handles
All holes have been drilled, tapped and reamed
Other side
While the handles were together in the reaming process, I went ahead and profiled the handle to 400 grit and after that I have lapped the flats again by hand
Here I am hand lapping a washer to make sure it is absolutely flat and parallel
I am checking the washers for thickness and consistancy
Writing down all my calculations and figuring out how everything is going to work
Boring out the pocket for the spring and the spacer. I love this machine
Measuring the depth of each cut
Sometimes I scare myself
I am milling a little channel to anchor the auto spring
Here is what it looks like on the inside with the spring and washers in place
Time to start the machining! About 2/3 of the handle is machined away
This is before I do my final cleaning and lapping on the inside of the handle. I want to make sure that all bumps or grooves are removed and it is absolutely flat. This is all done by hand with stones, sand paper and flat blocks
la suite demain
Messagepar Crocuta » 12 Mar 2008 02:12
AAARGH, c'est pas gentil ça pkt
Crocuta
Hyène Bien Fou
Messagepar Pierro » 12 Mar 2008 02:20
arf... le teasing de la mort qui tue!
Pierro
Messagepar .LuD. » 12 Mar 2008 11:25
joli reportage! vivement la suite !
Moonlight serait habillé de cuir en nous fouettant et hurlant "t'aimes ça hein ?" et s'arreterait d'un coup..pour boire une bière sous nos yeux, ce serait pareil: horrible attente, vivement que ca reprenne.
Messagepar CASH » 12 Mar 2008 11:30
Très intéressant! Mais sans cuir ni fouet pour moi! :D Joli boulot thup
CASH
Baywatch
Messagepar cram » 12 Mar 2008 12:19
Woooww !
Super intéressant. J'ai vu des machine dont je n'imaginais même pas qu'elles puissent être simplement imaginées :)
La haine seule fait des choix
cram
Messagepar Moonlight » 12 Mar 2008 14:33
allez la suite :D
Off to a good start. After my therapy I am feeling really strong today
Countersinking the spacer screw holes
Checking to see if the screw is laying below the surface. Everything is looking good here
Boring a pocket for the pivot pin
The pocket is bored in both handle to accept the pivot washer (time stamp)
Laying out the handle materials to be fitted
Cutting the handle materials
Mounting the handle on the mill
Machining the handle square
This is what the handles are going to look like (it will look better once I am done )
The handle materials have been drilled and counterbored for the 4 screws and profiled flush with the frame
Making the pivot pin screw (I took this picture by myself )
Pivot pin screws are made. They are completed and ready for assembly
Now I am making the pivot washers. This is stainless steel Damascus.
The washers are off the lathe; it is time for the milling.
Messagepar Moonlight » 12 Mar 2008 14:38
I am machining decorations on the pivot washer
Here it is done
I am going to start machining the slot for the E-Lock mechanism. It is not an easy mechanism to make and it is time consuming.
Half way thru the machining process
The machining is done for the rocker. How do you like the little chamfer around the slot? I have never done that before, looks nice.
Etching the pivot washer
Pivot washers are done
Messagepar Crocuta » 12 Mar 2008 14:38
Il me FAUT un Elishewitz :shock:
Crocuta
Hyène Bien Fou
Messagepar Moonlight » 12 Mar 2008 14:50
This was last night after a long hard day. I treated myself to a lot of calories
I am finding center on a rotary table with a .0001 indicator
Time stamp
Using my optical comparator to take a look at a tool and measure the curf and depth
The tool mounted on the mill and the rotary table ready to be used
Machining a radius groove around the finger groove
Cleaning out the groove
Polishing the groove on the buffer
The grooves around the finger groove are done
I am machining the next set of grooves
Close up of the second set of grooves
Cleaning the grooves
Polishing on the buffer
The second set of grooves is done
This is my final set of grooves being machined
Cleaning the grooves out
After the polishing
If you noticed I cleaned and polished each set of grooves separately. This was to maintain a crisp definition of the machining. It is a longer process but it is well worth it. In the photo I am doing the final polishing on the edge, the facets, the grooves with several different wheels and compounds.
Here I am lapping the flats with a 1200 grit paper. That will be the final finish for the flat surface.
The final result is a two tone, mirror and satin finish. Something to keep in mind: Each groove is deeper than the one next to it; so there is a sculpted effect on the handle.
The handles took longer than I expected and threw me way behind but the end result was well worth it.
Messagepar oufti » 12 Mar 2008 14:52
Je sais pas pourquoi mais je sent que je ne vais pas aimer...
En tout cas... la vache, il a du matos hein...
Messagepar .LuD. » 12 Mar 2008 14:52
Sérieux, j'halucine...et je viens d'aller sur son site..
dites, on est bien sur terre la ?
Messagepar Moonlight » 12 Mar 2008 14:58
Today I start working on the blade. I am flattening the blade on a disc grinder
Time stamp
Filing the little notch
Spotting the hole with the pattern
Drilling the pivot hole
Reaming and chamfering the pivot pin hole
The pivot pin hole is finished
First cut on the pantograph for the blood groove
Cutting the notches through the groove
Pantograph work is done
Laying out the groove and the holes for the auto spring
Drilling the tab holes where the spring will be anchored
Getting ready to bore the groove for the spring on the lathe
Boring
Checking the depth of the groove
Blind groove completed
Locating the blade in the closed position
Scribing the location of the rocker bar
Blade with the scribbed rocker
Messagepar ilium » 12 Mar 2008 15:00
oufti a écrit:Je sais pas pourquoi mais je sent que je ne vais pas aimer...
Je n'aime pas 99% de ce qu'il fait mais entre les surins, les montres et les stylos, il sait se servir de ses mains le monsieur. Impressionnant.
ilium
Maud Passeur
Messagepar Moonlight » 12 Mar 2008 15:06
Alors heu... juste pour faire une mise au point... oui c'est du Elishewitz, donc c'est du lourd, du chargé, on aime ou pas.
C'est pas le but de ce thread de montrer un couteau et de donner son avis dessus à tour de bras, sinon je l'aurais pas placer ici.
Je montre juste le processus de fabrication nécessaire pour un truc pareil. C'est tout.
Alors le résultat final, je peux déjà le montrer de suite pour faire vomir certains et baver d'autres, comme ça ça sera fait :
cron
