plate semelle en stock removal par Tom Krein
Messagepar Moonlight » 13 Mar 2008 10:29
découpe d'après modèle :
I decided that I wanted to build TWO knives this morning. I decided that I would build the same knife in an Old School Style and a more Modern take.
We will see if I can pull it off in the time constrants.….. Hopefully I can get'er done! I have to work my weekend shifts at the ER so that will kill 2 of my days. So the time constrant is a BIG concern for me.
First the Modern interpretation. It is going to be a CPM S30V blade with synthetic handles... not sure exactly what yet. Making decissions on the fly.
Second one is the Old School version. It is going to have a 5160 blade with some nice bolsters and natural scales. Not going to divulge all the details on this one yet.…. It is super secret!
Here are some pics of work in progress...
Here I am drilling the holes in the 5160 blade.…
Here I have the 5160 blade with the holes spotted and the profile scribed. It is ready to have the holes opened up and then it is off to the saw!
Running the band saw!
Grinding the profile on the 5160 blade...
Two blades profiled! Lets grind!
Messagepar stancaiman » 13 Mar 2008 10:32
en voilà un qui ne se prend pas au sérieux :D
Messagepar .LuD. » 13 Mar 2008 10:34
Excellent :)
Messagepar Moonlight » 13 Mar 2008 10:44
Finishing out the flats on the disk sander.
Flats are finished and the 5160 blade is ready for heat treatment. I get to play with fire!! Dan Koster will be talking me through the heat treatment of the 5160.
While waiting on Dan to arrive at the shop I decided to rough out the tappered tang on the S30V blade. It is .025" at the tip!
Messagepar CASH » 13 Mar 2008 10:47
Au moins il travaille dans la bonne humeur!
CASH
Baywatch
Messagepar Moonlight » 13 Mar 2008 10:50
The heat treat set up! This is Dan Kosters kiln, he just keeps it at my place! Works good for me That blur is me! I was moving FAST today!
I wanted to try for a hammon line(Dan said it was ify with 5160, but said it wouldn't hurt). This is me applying the clay.
This episode is sponsored by BEGG KNIVES! Buy BEGG KNIVES!
Here is the blade in the kiln
Forgot how thirsty heat treating can be!
Messagepar Moonlight » 13 Mar 2008 10:58
The knife is now in the quench plates.…
Its too early.…..
Grinding away on the tang of the 5160 blade!????? Have I gone crazy.….
That is a distinct possability! Ahhahahaha.….. (in my best maniac laugh)
Yes I think I may have been crazy all along. But grinding on the tang is not crazy it is part of my diabolic plan!
Messagepar Moonlight » 13 Mar 2008 11:07
Putting in some mill time! I am actually using it for something other than a storage table! What am I doing??? Keep watching for a few more minutes.…
Is that copper? Looks like it.…
I am making a copper wrapped tang. This is something that you don't really see anymore. It was popular in the 1960's and 1970's. They usually used brass or ns. I have never seen one with copper.
FIRE! Fire, fire, fire, fire.……
I think I might have been a pyro in a previous life!
Applying the high temp solder..
Cutting out the handle on the 5160 blade.
Messagepar Moonlight » 13 Mar 2008 11:14
Okay,just got done tappering the tang on the Copper wrapped 5160 blade. Here are the pics...
Setting the angles on the tappered tang.
Ready to go to the 10" grinder.
Grinding the hollow on the tang so it flattens much easier.
Ready for the disk sander!
Here the flats are finished to 320 grit straight from the disk sander. Ready to hand sand! WHAT FUN!
Here I am rubbing out the flats on the blades.…. This change of pace is fun!
Relearning why I don't do this too often..
GRINDER TIME!! This is what I live for!
Messagepar Moonlight » 13 Mar 2008 11:27
Give'n it to it on a 14" wheel
Here the blades are ready to go to the 400 grit belt and then hand rub out. Did not get as far as I had hoped today, but it was a GOOD day.
This was a tough shot! Did not quite get them held on a 90 degree angle, but close. The plunges are very close right now and will get the final tune on the 400 grit belt.
Lets see what the micrometer says about these blades! I have been trying to get them as close as posable.…
Copper wrapped 5160 blade first.…
Still the copper wrapped tang 5160 blade. If you have any questions take a look at the edge of the blank. On the 5160 blade you can see the slight decarb from the HT process. This is not present on the S30V blade that was heat treated in a controlled atmosphere kiln by Paul Bos.
The first thing I did was decide that I wanted the grind lines a little higher and more refined, so I went back to the 240 grit belts.
(le flingue est là au cas où la machine s'emballe)
Finally making some progress! Got the grinds up where I want them.….
Working on the 400 grit belts! After seeing the picture my dad reminded me that I had a problem learning how to ride a bike as I never would watch where I was going...
I told him I had to grind by feel.…..
Unless working on perfecting my new two handed grinding style.….
Concentration this takes.…. (in my best Yoda voice)
This was a daring move! Two handed and not watching..
On to the 15 micron belt. Next step is to get the ground bevels hand rubbed out.
Messagepar Moonlight » 13 Mar 2008 11:32
Imagine the jingle playing in the back ground.…… Mr. Clean, Mr. Clean.….
Okay, the flats and bevels are hand rubbed to a nice satin finish. It is now time to etch my "Krein Knives" Logo on the bevels.
Here is a close up of the elctro-chemical etch process.
Now I have to clean up the logo's by hand rubbing them again! This will clean up any "fuzzy" edges and make them nice and sharp!
Messagepar Moonlight » 13 Mar 2008 11:39
I am finally finished with the blades! I have the swedges ground in and hand rubbed out.
Here I am rough grinding the swedge. I do this on a smooth 10" wheel with the knife held vertical.
Those 5160 sparks are hot as hell on the finger! Weird how D-2 and S30V sparks are not hot at all!
Messagepar Roland L » 13 Mar 2008 11:50
Ca ressemble plus à la coutellerie que je connais que les deux précédents reportages.
Les deux autres couteaux sont très chouettes, mais on voit bien qu'il s'agit d'un autre univers...
Roland L
Electron sonneur
Messagepar Lorgar » 13 Mar 2008 12:02
Merci Moon, je me régale à voir ce type bossé dans la bonne humeur il est juste un peu cintré!
Lorgar
Loreflet de lame
Messagepar Moonlight » 13 Mar 2008 12:03
Time to make the bolsters! These should be a LOT of fun.….
First I filled the oversize pin holes with brass rod so I could easily spot my holes and make them the correct size.
Here I have the holes drilled in the brass and the shape drawn out on the tang. I have drilled the copper bolsters and have them ready to band saw.
Cutting the double black Ebony linen micarta for the bolsters of the S30V knife.
Polishing the fronts of the bolsters.…
Putting the high polish on the fronts of the Copper bolsters...
Here is a close up of the fronts of the bolsters...
Next I have to dovetail the bolsters and handle material.…
cron
