pliant tactique par J Krammes
Messagepar Moonlight » 13 Mar 2008 12:32
My materials are, S-30-V blade, still with the HT coloring on it. Some .085 Ti for the liners, carbon fiber scales, stanless bolsters, and a Ti spine.
To get the juices flowing this morning, I started the day off with some Fear Factory.
1st person view of cutting out the liners.
Match drilling the liners.
Cutting out the Ti spine.
Punching out washers form a sheet of Nylatron.
Drilling holes for the 4-40 screws to hold it all together.
The final pic before I eat lunch.
Taping the 4-40 holes.
Profiling the liners together.
Starting to look like a knife.
Final shot for the day.
Messagepar Moonlight » 13 Mar 2008 12:36
et dire que je bosse à côté rptd
Messagepar CASH » 13 Mar 2008 12:38
On en est tous la, mon pov' Moosieur! rptd rptd
CASH
Baywatch
Messagepar Moonlight » 13 Mar 2008 12:38
Day 2...
I started off the morning grinding the lock face on the tang of the blade.
Layout of the lock on the liner.
Cutting the long leg of the lock.
Cutting the short leg.
Grinding the relief in the lock bar.
Rounding off the head of the pivot on my "lathe" .
Final shot before lunch.
Messagepar Moonlight » 13 Mar 2008 12:41
A few more...
Marking the location for the detent.
Pressing the Detent in after drilling.
Marking the blade for the Detent divot.
Blade lock up.
Blade in closed position.
Layout for bolsters and scales.
Drilling, cutting, and then profiling the bolsters.
Here's where I'm at right now.
Messagepar Moonlight » 13 Mar 2008 12:43
I started on the scales.
I finish my bolsters first, then I fit my scales to the bolsters. I don't have a pantograph, so this is done with the grinder and files. I hate this part. When the fit looks good held up to the light, I mark the scale and bolster, then superglue the scale in place.
I drill the holes for the scales through the liners.
The final shot for the night. The liner soaking in Feric because of the tap I broke in the last hole I had to thread...
Messagepar Moonlight » 13 Mar 2008 12:45
Fit the scale to liner.
Drilling the back of the bolster for a hidden pivot.
Me in my CF gear.
Here's where I'm at now.
Messagepar Moonlight » 13 Mar 2008 12:48
Still makin dust...
Here is a little more scale work.
I round my bolsters first, then I put on the scales and match them to the bolsters.
Here are the bolsters and scales mostly finished.
Grinding in the thumb ramp to get to the thumb stud.
Fileing notches in the lock bar. First I use a 3 square to mark the spot, then I go back with a round file to finish.
Messagepar Moonlight » 13 Mar 2008 12:50
I decided to do a little drilling on the spine.
Work on the pocket clip.
I'll call it a night with this one.
Messagepar Moonlight » 13 Mar 2008 12:51
la suite après manger... ;)
Messagepar John Shannow » 13 Mar 2008 12:55
Moonlight a écrit:la suite après manger... ;)
allez grouille! :lol:
président à vie du CJCEP
Membre du PPP.
John Shannow
Toniglandyl
Messagepar Davless » 13 Mar 2008 13:43
Par rapport aux autres il bosse beaucoup plus à la main ….
Davless
L'oeil du tigre...
Messagepar Moonlight » 13 Mar 2008 13:46
I started off with the thumb studs.
I needed a little more gription on the studs, so I decided to use my high speed rotery tool and put little divots all over the dome.
Then I go back a stipple over the divots to even things out.
Here they are installed.
Next I preped the liners for bead blasting.
In the blast cabinet.
After blasting.
I'll be grinding the blade tonight sometime.
Messagepar Moonlight » 13 Mar 2008 13:48
Time to do some grindin...
Some 60 grit on a 10" wheel.
After 60 grit.
After 400 grit.
Then I go onto hand sanding with some WD40 and elbo grease.
Then I go onto the swedge. I do this on the platen in an almost verticle position.
Final pic for the night. Almost there.
Messagepar Moonlight » 13 Mar 2008 13:52
I started the day off with sharpening the blade. I put most of the edge on with the grinder, then I finish off with a vice and stones at 20 degrees.
Hair popping sharp.
Time to etch my mark on the blade with an Electro Etch system.
The stainless bolsters are stainless damascus... Here they are in some Sulferic acid.
I wanted a subtle look so I went with some 30 turn Damasteel.
Time for final assembly. I use Super Lube on the pivot area, and some blue Loc Tite on the screws.
I will post the finished pics in a new thread.
cron
